Global Packet Tracing
By esupport posted Nov 25, 2015 06:59 PM
The tracing feature is important for debugging the sequence of events that occur inside a process or protocol, for example message processing, state machine transitions, configuration change events, or timer events.
Starting from ArubaOS 7.4.1, Mobility Access Switch introduces the following CLI commands to enable global and ACL-based packet tracing:
  • pkt-trace-global enable
  • pkt-trace acl <ACL-name> enable
Enabling Global Packet Tracing:
Execute the following CLI command to enable global packet tracing:
(host) # pkt-trace-global enable
Execute the following CLI command to disable global packet tracing:
(host) # pkt-trace-global disable
The following table describes the parameters of the pkt-trace-global enable command:
trace  --> Configures datapath trace options.
trace-hex-mask <tmask> --> Configures datapath trace mask in Hex format.
Sample Configuration:
The following sample pkt-trace global command configures trace mask for ACL functionality:
(host) # pkt-trace-global enable trace-hex-mask 0 trace acl-processing
Enabling ACL-based Packet Tracing
Execute the following CLI command to enable packet tracing for an ACL entry:
(host) # pkt-trace acl <ACL-name> enable
Execute the following CLI command to disable packet tracing for an ACL entry:
(host) # pkt-trace acl <ACL-name> disable
The following table describes the parameters of the pkt-trace acl enable command:
log: Writes packet trace data into log file.
trace: Configures datapath trace options.
trace-hex-mask <tmask>:  Configures datapath trace mask in Hex format.
The following sample pkt-trace acl command writes packet trace data into log file for the stated ACL bug:
(host) #pkt-trace acl acl-bug-58651 enable log trace acl-processing
Verifying Packet Tracing Configuration:
The following show command helps verify the packet tracing configuration:
(host) #show datapath debug trace-buffer
Datapath Trace Buffer Entries:
MacAddr( bb) 0x0 0x0 0x0 0x0 0xb86a1
0x6ac00000
0x6ac00000
0x6ac00000
CPDNSok( 4f) 0x0 0x1 0xa1045a2 0x37 0x1f
0x0
Note: The show command output may not completely imply that the packet tracing configuration is set. Enabling packet tracing might impact the throughput of the system.
