Update/Change Controller Firmware
By esupport posted Dec 08, 2016 05:30 PM
Q:
How do I update or change the firmware for Aruba controller products?
ASE Link:  Go to the solution
A:
Summary
The solution will allow you to update your controller's AOS image to a different version.  Generally a AOS controller has two system partitions from which you can choose to boot from.  This solution can directly update the bootable system partition in flash or you may decide to modify this according to your needs.
You will require one of the following:
  • USB drive (FAT32 formatted)
  • Network connected FTP, TFTP, or SCP server
Software Version(s) Required
Aruba OS 5.x - 8.x
Platform(s) Tested
Aruba OS 6.x, 7.x, or 8.x
Licenses
None
References
