How to configure IAPs as Mesh Portal and Point?
By Arunkumar posted Jul 16, 2014 01:21 PM
Mesh Portal and Point help establish connection between 2 points, mostly over a longer distance where wired connectivity is not feasible.
IAPs can be used to achieve the same. This articles explains how a pair of IAP can be configured as Mesh Portal and Mesh Point.
Environment : Indoor or Outdoor Mesh Environment.
Network Topology : Switches======== IAP Mesh Portal ========= IAP Mesh Point=========Switches.
Below are the steps to configure an IAP Mesh Network:
  1. Connect both IAPs to a LAN network.
  2. They should form a cluster as usual.
  3. By default all the IAPs are capable of functioning as Mesh Portal.
  4. To configure the Mesh Point, goto the access point tab in UI.
  5. Click the access point you want to configure as Mesh Point.
  1. Click edit and go to uplink tab. Enable Eth0 bridging.
  1. This would enable the IAP mesh point to use its Eth0 port as downlink and identify that it has to function as a Mesh Point.
  2. The IAP Mesh Point can now to unplugged and plugged where necessary.
  3. The Mesh Portal and Point will form a Mesh link once the Point comes up.
To verify if the Mesh Portal and Point have formed a link, below commands can be run.
 9/23/2013 20:11:25 PM    Target: 6c:f3:7f:c4:0b:4c    Command: show ap mesh link
Neighbor list
MAC                Portal             Channel  Age  Hops  Cost  Relation      Flags  RSSI  Rate Tx/Rx  A-Req  A-Resp  A-Fail  HT-Details       Cluster ID
6c:f3:7f:c0:b5:11  6c:f3:7f:c0:b4:d0  161+     0    1     7.00  C 5h:36m:24s  HLK    65    6/6         1      1       0       HT-40MHzsgi-3ss  8071044095124fd7a54e5db8468a3b1
Total count: 1, Children: 1
Relation: P = Parent; C = Child; N = Neighbor; B = Blacklisted-neighbor
Flags: R = Recovery-mode; S = Sub-threshold link; D = Reselection backoff; F = Auth-failure; H = High Throughput; L = Legacy allowed
    K = Connected; U = Upgrading; G = Descendant-upgrading; Z = Config pending; Y = Assoc-resp/Auth pending
    a = SAE Accepted; b = SAE Blacklisted-neighbour; e = SAE Enabled; u = portal-unreachable; o = opensystem
 9/23/2013 20:11:57 PM    Target: 6c:f3:7f:c4:0b:4c    Command: show aps
AP List
Name               IP Address    Mode    Spectrum  Clients  Type  Mesh Role  2.4 Channel  2.4 Power (dB)  2.4 Utilization (%)  2.4 Noise Floor (dBm)  5.0 Channel  5.0 Power (dB)  5.0 Utilization (%)  5.0 Noise Floor (dBm)  Need Antenna Config  From Port  Config Id
6c:f3:7f:c4:0b:4c  10.10.45.253  access  disable   0        135   Portal     1            21              95(poor)             -90(good)              161-         20              25(good)             -87(ok)                No                   none       5
6c:f3:7f:c4:0b:50  10.10.45.254  access  disable   0        135   Point      11           21              91(poor)             -87(ok)                161-         20              25(good)             -92(good)              No                   none       5
Flat Slave AP Count:1
Hierarchy Slave AP Count:0
2 comments
1 view
Comments
Sep 06, 2019 07:47 AM
Please suggest how can we further connect a ethernet switch to Mesh Point and extend the LAN network.
Jul 18, 2016 02:08 PM
I can´t do the mesh configuration on two IAP 103 version 6.4.3.1-4.2.0.3 without controller,
Thanks for you help.
show this:
Mesh point# show ap mesh link
No mesh supported in current mode
mesh point#
