What to do when we see incorrect AP database information on a Local controller
By esupport posted Jul 06, 2015 08:24 AM
Q:
Issue: There Might be  getting a  Situation When the Ap status will be up on the master controller but the same database status will be  down in the local
Sample outputs
#show ap database(Master controller)
AP00161-6c:f3:7f:ca:11:c9  T1-VLAN801- 105      10.9.47.126  Up 71d:9h:19m:32s   2      10.60.0.202  0.0.0.0     6c:f3:7f:ca:11:c9  BT0243885  N/A   N/A   N/A
AP00252-6c:f3:7f:cd:68:46  T1-VLAN799 135      10.8.47.88   Up 71d:9h:18m:53s   2      10.60.0.202  0.0.0.0     6c:f3:7f:cd:68:46  AX0189011  N/A   N/A   N/A
show ap database long  (Local controller)
AP00161-6c:f3:7f:ca:11:c9  T1-VLAN801- 105      10.9.47.126  Down 71d:9h:19m:32s   2      10.60.0.202  0.0.0.0     6c:f3:7f:ca:11:c9  BT0243885  N/A   N/A   N/A
AP00252-6c:f3:7f:cd:68:46  T1-VLAN799 135      10.8.47.88   Down 71d:9h:18m:53s   2      10.60.0.202  0.0.0.0     6c:f3:7f:cd:68:46  AX0189011  N/A   N/A   N/A
A:
Solution
We can execute the following command from the master controller
'clear gap-db lms lms-ip <ip_of_local controller)
This command will help in clearing the stale entries in the local controller mapped to the lms and update the right status.
