Requirement:ArubaOS Switch
Solution:In the following example, switch Rack2sw1 is configured to send an event message to the Syslog host when the running configuration is changed.
Configuration:Rack2sw1(config)# logging 10.250.101.177
Rack2sw1(config)# logging notify running-config-change transmission-interval 2
VerificationRack2sw1# show syslog notifications
Syslog Notifications Information
Type | Status TX Interval
Running Config Change | Enabled 2
Rack2sw1# show syslog config
Syslog Configuration
Syslog Facility : user
Syslog Severity : debug
Syslog System Module : all-pass
Syslog Priority Description :
Syslog Server Details
Syslog Server Address/Host Name L4 Port Syslog Control Descr PerIp
10.250.101.177 UDP 514 No
---------- Testing -----------
Core-Switch(config)# interface 26 name NewName
---------- Syslog Received Message ----------
<12>Apr 26 00:47:10 10.250.101.169 notice: Notice-Type='Running Config Change',Event-ID='3165',Config-Method='CLI',Device-Name='Rack2sw1',User-Name='manager',Remote-IP-Address='127.0.0.1' 10.250.101.169 25/04 17:51:26.582
---------- Wireshark Trace ----------
Ethernet II, Src: HewlettP_b4:84:40 (54:80:28:b4:84:40), Dst: HewlettP_ea:30:08 (ac:e2:d3:ea:30:08)
Internet Protocol Version 4, Src: 10.250.101.169, Dst: 10.250.101.177
User Datagram Protocol, Src Port: 514, Dst Port: 514
Syslog message: USER.WARNING: Apr 26 00:53:21 10.250.101.169 notice: Notice-Type='Running Config Change',Event-ID='3169',Config-Method='CLI',Device-Name='Rack2sw1',User-Name='manager',Remote-IP-Address='127.0.0.1'
0000 1... = Facility: USER - random user-level messages (1)
.... .100 = Level: WARNING - warning conditions (4)
Message: Apr 26 00:53:21 10.250.101.169 notice: Notice-Type='Running Config Change',Event-ID='3169',Config-Method='CLI',Device-Name='Rack2sw1',User-Name='manager',Remote-IP-Address='127.0.0.1'
Syslog timestamp (RFC3164): Apr 26 00:53:21
Syslog hostname: 10.250.101.169
Syslog process id: notice
Syslog message id: : Notice-Type='Running Config Change',Event-ID='3169',Config-Method='CLI',Device-Name='Rack2sw1',User-Name='manager',Remote-IP-Address='127.0.0.1'
---------- Local Testing ----------
Rack2sw1# debug ip packet
Rack2sw1# debug destination buffer
Rack2sw1# show debug
Debug Logging
Source IP Selection: Outgoing Interface
Origin identifier: Outgoing Interface IP
Destination:
Memory buffer
Time-stamp: System-Uptime
Enabled debug types:
ip packet
Rack2sw1# configure terminal
Rack2sw1(config)# interface 26 name New-Name
Rack2sw1# show debug buffer | include 10.250.101.177
0023:02:00:23.23 IP InetServer:s=10.250.101.169 d=10.250.101.177(vl1000) xmit
