Stop and start VisualRF from AirWave command line
By ozerdo posted Nov 13, 2011 10:50 PM
Question
I am trying to stop and start (or say disable and enable) VisualRF from AirWave command line. Can any one please let me know the command or query?
Answer
AirWave has a process called ServiceWatcher whose job is to restart VisualRF if it's configured to be on and it's not running. So it's a 2-step process to stop it and a 1-step process to start it.
To Stop it:
1. Set it to disabled in the database:
# dbc "update seas_config set visualrf_enabled = 0";
2. Stop the java process:
# killall java
To Start it:
1. Just set it to enabled in the database, and ServiceWatcher will start it:
# dbc "update seas_config set visualrf_enabled = 1";
