LMS IP configuration in 8.0
By esupport posted Mar 30, 2017 06:24 AM
Q:
How to configure "LMS IP" address in Aruba OS 8.0?
A:
LMS-IP configuration was always been part of AP system profile within an AP Group. Starting Aruba OS 8.0, LMS IP for AP redundancy can now be directly configured from AP group itself. Whatever address configured for LMS/Backup-LMS from AP group under LMS, will reflect in the AP system profile too.
LMS Configuration Prior to  8.X
Navigate to the Configuration > Wireless > AP Configuration > AP Group > Select the AP Group > AP System profile > LMS-IP Configuration
LMS Configuration in 8.0
Select a Controller or a Group, navigate to Configuration > AP Groups > LMS Configuration
As you can see in the above screenshot, the IP address configured in the LMS and Backup LMS directly under the AP group is reflected in the AP system profile too.
Navigate to Configuration > AP Groups > Profiles > AP Group > AP > AP system > LMS Settings
1 comment
1 view
Comments
Apr 22, 2019 12:03 AM
dear @esupport,
i'm already set LMS IP between 2 cluster
but after controller with primary lms ip up, access point wont change switch ip to primary lms ip, just stay in back up lms ip,
can you please advice me how to do it ? even i'm already check the pre emption config
