How can we get all the AP provisioning information to a text file from an ArubaMM?
By esupport posted Apr 01, 2017 01:25 AM
Q:
A:
We can get the provisioning parameters of all the Access Points into a text file and save it to the controller flash. We can then TFTP the file from the controller flash to our local computer for future references.
(ArubaMM) [mynode] #
(ArubaMM) [mynode] #ap consolidated-provision info
Command Completed Successfully, Please retrive results in ap_provision_info.txt file
(ArubaMM) [mynode] #dir
-rw-r--r--    1 root     root        61751 Mar 31 09:39 AUDITTRAIL-HISTORY.log
-rw-r--r--    1 root     root        29383 Mar 31 09:39 AUDITTRAIL-LOGIN_OUT-HISTORY.log
-rw-r--r--    1 root     root        71931 Feb 28 13:54 airmatch_db_dump.tgz
-rw-r--r--    1 root     root          331 Mar 31 10:22 ap_provision_info.txt
-rw-r--r--    1 root     root        13024 Jan 11 11:00 default.cfg
drwxr-sr-x    4 root     root         4096 Jan 11 11:01 fieldCerts
-rw-r--r--    1 root     root        54535 Feb 19 15:28 flashbackup.tar.gz
Below is the sample of the details extracted from the controller as I had only one AP attached to the controller.
ap name: AP1
ipv4 address type: dynamic
ipv4 address: 10.17.171.125
ipv4 netmask: 255.255.255.224
ipv4 gateway: 10.17.171.98
ipv4 lease: 43200
ipv4 dhcp server: 10.17.171.98
ipv4 dns server: 0.0.0.0, 0.0.0.0
ipv6 address: none
master: 10.17.171.99
master discover type: ADP
previous lms: 10.17.171.99
lms addrs [0]: 10.17.171.99
