Aruba 3810M – How to Configure Basic IPV4 BGP Routing
By esupport posted May 29, 2020 12:12 PM
This article discusses how to configure basic IPV4 BGP routing.
In the following example, switches Rack2sw1 and Rack2sw2 are configured for BGP routing.
 • IP addresses are configured on the VLAN 1 and Loopback 0 interfaces.
 • BGP routing is enable for the autonomous system ID 12.
 • Connected interfaces are redistributed into BGP.
********** Configure IP interfaces **********
Rack2sw1(config)# interface loopback 0 ip address 1.1.1.1
Rack2sw1(config)# vlan 1 ip address 192.168.12.1/24
********** Configure BGP routing **********
SWITCH 1
Rack2sw1(config)# ip routing
Rack2sw1(config)# router bgp 12 neighbor 192.168.12.2 remote-as 12
Rack2sw1(config)# router bgp 12 enable
Rack2sw1(config)# router bgp 12 redistribute connected
SWITCH 2
Rack2sw2(config)# ip routing
Rack2sw2(config)# router bgp 12 neighbor 192.168.12.1 remote-as 12
Rack2sw2(config)# router bgp 12 enable
Rack2sw2(config)# router bgp 12 redistribute connected
SWITCH 1
Rack2sw1# show ip bgp summary
 Peer Information
  Remote Address  Remote-AS Local-AS State         Admin Status
  192.168.12.2    12        12       Established   Start
Rack2sw1# show ip bgp neighbor 192.168.12.2 advertised-routes
  Status codes: * - valid, > - best, i - internal, e - external, s - stale
  Origin codes: i - IGP, e - EGP, ? - incomplete
     Network            Nexthop         Metric     LocalPref  Weight AsPath
*>i  1.1.1.1/32         192.168.12.1    0          100        32768           ?
*>i  192.168.12.0/24    192.168.12.1    0          100        32768           ?
Rack2sw1# show ip bgp neighbor 192.168.12.2 received-routes
*>i  2.2.2.2/32         192.168.12.2    0          100        0               ?
  i  192.168.12.0/24    192.168.12.2    0          100        0               ?
Rack2sw1# show ip route bgp
                                IP Route Entries
  Destination        Gateway         VLAN Type      Sub-Type   Metric     Dist.
  2.2.2.2/32         192.168.12.2    1    bgp       internal   0          200
SWITCH 2
Rack2sw2# show ip bgp summary
 Peer Information
  192.168.12.1    12        12       Established   Start
Rack2sw2# show ip bgp neighbor 192.168.12.1 advertised-routes
*>i  2.2.2.2/32         192.168.12.2    0          100        32768           ?
*>i  192.168.12.0/24    192.168.12.2    0          100        32768           ?
Rack2sw2# show ip bgp neighbor 192.168.12.1 received-routes
*>i  1.1.1.1/32         192.168.12.1    0          100        0               ?
  i  192.168.12.0/24    192.168.12.1    0          100        0               ?
Rack2sw2# show ip route bgp
                                IP Route Entries
  1.1.1.1/32         192.168.12.1    1    bgp       internal   0          170​
CONNECTIVITY VERIFICATION
Rack2sw1# ping 2.2.2.2
2.2.2.2 is alive, time = 1 ms
Rack2sw2# ping 1.1.1.1
1.1.1.1 is alive, time = 2 ms
