Distributed Trunking Cheat Sheet
By esupport posted Sep 30, 2020 10:36 PM
Q:
Is there a Distributed Trunking Cheat Sheet?
A:
You must configure the ISC ports before you can configure the trunks for distributed trunking.
To configure an ISC port, enter this command:
Syntax: switch-interconnect <port-num | trk1...trkN>
                switch-interconnect  b21
To configure distributed trunking on the switch, enter this command:
Syntax: trunk <port-list> <trk1 | trk2 ... trkN> [trunk | lacp | dt-lacp] no trunk <port-list>      trunk b11 trk1 dt-lacp
Configures distributed trunking on a switch. Use the dt-lacp option. The trunk groups must be identical in both switches, for example, if Switch Local is configured with trk1 and uses the dt-lacp option, Switch Remote must be configured with trk1 and use the dt-lacp option also in order to form a Distributed Trunk.
Example of Configuring Distributed Trunking:
ProCurve Switch Local(config)# switch-interconnect a7
ProCurve Switch Remote(config)# switch-interconnect b9
ProCurve Switch Local(config)# trunk a9 trk10 dt-lacp
ProCurve Switch Remote(config)# trunk a9 trk10 dt-lacp
To display information about the distributed trunks, enter the show lacp distributed command.
Syntax: show lacp [distributed]
Distributed Trunking Restrictions
There are several restrictions with distributed trunking.
■ The port trunk links should be configured manually (manual LACP). Dynamic linking across switches is not supported.
■ Only servers are supported as Distributed Trunking Devices (DTDs).
■ A distributed trunk can span a maximum of two switches.
■ A maximum total of 60 servers can be connected to two DT switches. Each server can have up to four physical links aggregated in a single switch, meaning that there can be a maximum of eight ports (four aggregated links for each DT switch) included in a DT trunk.
■ Only one ISC link is supported per switch with a maximum of 60 DT trunks supported on the switch. The ISC link can be configured as a manual LACP trunk, non-protocol trunk, or as an individual link. Dynamic LACP trunks are not supported as ISCs.
■ An ISC port becomes a member of all VLANs that are configured on the switch. When a new VLAN is configured, the ISC ports become members of that VLAN.
■ Port trunk links can be done only on a maximum of two switches that are connected to a specific server.
■ Any VLAN that is in a distributed trunk must be configured on both switches. By default, the distributed trunk belongs to the default VLAN.
■ There can be eight links in a distributed trunk grouped across two switches, with a limit of four links per distributed trunking switch.
■ The limit of 60 manual trunks per switch includes distributed trunking manual trunks as well.
IP routing and distributed trunking are mutually exclusive. Routing restrictions with distributed trunking are switch-wide and do not apply to the DT ports only.
■ Meshing and DT switches are mutually exclusive.
■ ARP protection is not supported on the distributed trunks.
■ STP is disabled on DT ports.
■ QinQ in mixed VLAN mode and distributed trunking are mutually exclusive.
■ SVLANs in mixed mode are not supported on DT or ISC links.
DHCP snooping and IGMP snooping are not supported on DT links.
2 comments
Comments
Feb 25, 2021 03:21 PM
This document is quite old I guess.
I remember that IP routing and connecting switches instead of only servers to distributed trunks was supported in early KX.15. versions.
Oct 01, 2020 10:59 AM
To be clear, does the restriction "IP routing and distributed trunking are mutually exclusive. Routing restrictions with distributed trunking are switch-wide and do not apply to the DT ports only." mean that VRRP can't be implemented on a pair of already "DT interconnected" chassis? Thanks.
