ArubaOS-Switch – How To Configure SNMP Traps And Trap Host
By esupport posted Apr 27, 2020 11:19 AM
ArubaOS Switches
In the following example, switch Rack2sw1 is configured for the Running-Config-Change trap and a Trap host.
Debugging for SNMP PDUs (Protocol Data Units) is enabled, and the configuration is changed, which triggers the SNMP trap.
---------- SNMP Trap destination configuration/verification ----------
Rack2sw1(config)# snmp-server host 10.0.104.100 informs community public
Rack2sw1# show snmp-server | begin Events
  Address                    Community            Events   Type     Retry   Timeout
  10.0.104.100           public                      None     inform   3           15
---------- Enable the running config change trap ----------
Rack2sw1(config)# snmp-server enable traps running-config-change
---------- Enable debugging for SNMP PDU messages ---------
Rack2sw1# debug destination session
Rack2sw1# debug snmp pdu
Rack2sw1# show debug
 Debug Logging
  Source IP Selection: Outgoing Interface
  Origin identifier: Outgoing Interface IP
  Destination:
   Session
  Time-stamp: System-Uptime
  Enabled debug types:
   snmp pdu
---------- Change the running configuration ----------
Rack2sw1(config)# hostname Rack2sw1-New
---------- Debugging output ----------
0020:23:20:17.76 SNMP mSnmpEvt:Outgoing Packet: addr = 10.0.104.100:162,length = 256
0020:23:20:17.76 SNMP mSnmpEvt:Version: 1
0020:23:20:17.76 SNMP mSnmpEvt:Community: public len:6
0020:23:20:17.76 SNMP mSnmpEvt:30 81 fd 02 01 01 04 06 70 75 62 6c 69 63 a6 81
0020:23:20:17.76 SNMP mSnmpEvt:ef 02 01 05 02 01 00 02 01 00 30 81 e3 30 10 06
0020:23:20:17.76 SNMP mSnmpEvt:08 2b 06 01 02 01 01 03 00 43 04 0a cc e5 b5 30
0020:23:20:17.76 SNMP mSnmpEvt:1f 06 0a 2b 06 01 06 03 01 01 04 01 00 06 11 2b
0020:23:20:17.76 SNMP mSnmpEvt:06 01 04 01 0b 02 0e 0b 05 01 07 01 1d 01 00 07
0020:23:20:17.76 SNMP mSnmpEvt:30 19 06 13 2b 06 01 04 01 0b 02 0e 0b 05 01 07
0020:23:20:17.76 SNMP mSnmpEvt:01 1d 01 0c 06 01 02 02 02 0c 29 30 18 06 13 2b
0020:23:20:17.76 SNMP mSnmpEvt:06 01 04 01 0b 02 0e 0b 05 01 07 01 1d 01 0c 06
0020:23:20:17.76 SNMP mSnmpEvt:01 03 02 01 01 30 18 06 13 2b 06 01 04 01 0b 02
0020:23:20:17.76 SNMP mSnmpEvt:0e 0b 05 01 07 01 1d 01 0c 06 01 04 02 01 01 30
0020:23:20:17.76 SNMP mSnmpEvt:1b 06 13 2b 06 01 04 01 0b 02 0e 0b 05 01 07 01
0020:23:20:17.76 SNMP mSnmpEvt:1d 01 0c 06 01 05 04 04 10 d6 c2 79 30 1e 06 13
0020:23:20:17.76 SNMP mSnmpEvt:2b 06 01 04 01 0b 02 0e 0b 05 01 07 01 1d 01 0c
0020:23:20:17.76 SNMP mSnmpEvt:06 01 06 04 07 6d 61 6e 61 67 65 72 30 22 06 13
0020:23:20:17.76 SNMP mSnmpEvt:06 01 07 04 0b 07 e4 04 17 16 0c 17 00 2d 00 58
---------- Wireshark Output ---------
Ethernet II, Src: HewlettP_b4:84:40 (54:80:28:b4:84:40), Dst: VMware_21:e6:6b (00:0c:29:21:e6:6b)
Internet Protocol Version 4, Src: 10.0.104.1, Dst: 10.0.104.100
User Datagram Protocol, Src Port: 161, Dst Port: 162
Simple Network Management Protocol
    version: v2c (1)
    community: public
    data: informRequest (6)
        informRequest
            request-id: 7
            error-status: noError (0)
            error-index: 0
            variable-bindings: 8 items
                1.3.6.1.2.1.1.3.0: 181243779
                    Object Name: 1.3.6.1.2.1.1.3.0 (iso.3.6.1.2.1.1.3.0)
                    Value (Timeticks): 181243779
                1.3.6.1.6.3.1.1.4.1.0: 1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.0.7 (iso.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.0.7)
                    Object Name: 1.3.6.1.6.3.1.1.4.1.0 (iso.3.6.1.6.3.1.1.4.1.0)
                    Value (OID): 1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.0.7 (iso.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.0.7)
                1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.2: 3115
                    Object Name: 1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.2 (iso.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.2)
                    Value (Integer32): 3115
                1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.3: 1
                    Object Name: 1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.3 (iso.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.3)
                    Value (Integer32): 1
                1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.4: 1
                    Object Name: 1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.4 (iso.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.4)
                1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.5: 10d6c279
                    Object Name: 1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.5 (iso.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.5)
                    Value (OctetString): 10d6c279
                1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.6: 6d616e61676572
                    Object Name: 1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.6 (iso.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.6)
                    Value (OctetString): 6d616e61676572
                1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.7: 07e40417161326002d0058
                    Object Name: 1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.7 (iso.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.7)
                    Value (OctetString): 07e40417161326002d0058
---------- Trap information for OID 1.3.6.1.4.1.11.2.14.11.5.1.7.1.29.1.12.6.1.3 ----------
hpSwitchRunningCfgChgEventMethod OBJECT-TYPE
SYNTAX INTEGER {
unknown (0),
cli (1),
menu (2),
snmp (3),
webUI (4),
internalEvent (5)
MAX-ACCESS read-only
STATUS current
DESCRIPTION "Indicates the source through which change to running config was initiated."
