How to configure MASTER L3 Redundancy
By esupport posted Jul 28, 2016 01:56 PM
  • Branch-config-group in primary master needs to be manually synced with backup master
  • Default switchover time to secondary master incase primary master goes unreachable is 15 minutes
Topology
  • Starting from AOS 6.4.4 BOC can have a backup master situated at a different geographical location
  • Secondary master will allow layer 3 redundancy by being ready to take over incase primary master is not reachable
  • HCM (Health check manager) will monitor secondary master as well
  • Support for manual switchover to backup master is also available
Master redundancy switchover default value
(Aruba7010) #show branch master-l3redundancy switchover-timeout
  switchover-timeout: 15 minutes
Support range 15-60 minutes
When primary master goes unreachable status shows red
(7010-B1) #show branch master-l3redundancy status
L3 Redundancy Status
Role              IP Address  Status
Master            10.16.66.6  Down
Secondary Master  10.16.66.7  Up
Health-check and uplink status
(7010-B1) #show ip health-check
IP Health-check Entries
Probe IP     Src Interface  State  Probe-Profile  Avg RTT(in ms)
10.16.66.6   --             Down   default        0
10.16.66.6   vlan 200       Down   default        0      >>>> Primary master reachablility status
10.16.66.6   vlan 4094      Down   default        0
10.16.66.7   --             Up     default        0       >>>> secondary master reachability status
192.168.2.1  --             Up     default        0     >>>> default gateway
(7010-B1) #show uplink
Uplink Manager: Enabled
Uplink Health-check: Enabled
Uplink Management Table
Id  Uplink Type  Properties  Priority  State      Status      Reachability
1   Wired        vlan 200    150       Standby    Ready       Unreachable
2   Wired        vlan 4094   200       Connected  * Active *  Unreachable
Troubleshooting
 #master-l3redundancy switchover
I.This is an action command to trigger forced switchover from primary to secondary master
II.Manual switchover subverts HCM and does not make any check regarding secondary master status I.e. master will switched over to backup master even if backup master is not UP
Config command:
   (branch-group-<id>)# master-l3redundancy switchover-timeout <timeout>
Show commands:
For debugging any issues associated with this feature – the following logging levels  should be set and logs examined
•system    debugging  N/A           crypto
•system    debugging  N/A           cfgm
•system    debugging  N/A           bocmgr
•system    debugging  N/A           fpapps
•system    debugging  N/A           dhcpd
•system    debugging  N/A           hcm
1 comment
Comments
Aug 21, 2016 09:58 AM
Glad to see this solution is now available.
Just wondering if L3 master redundancy between data centersd is supported by Aruba?
Thanks in advance,
-bill
