Locate tab does not work after upgrade to 6.4.3.x
By esupport posted Mar 08, 2016 04:24 PM
Q:
Why does the locate tab not function post upgrade to 6.4.3.x ?
A:
On the webUI, navigate to Dashboard --> Security --> Discovered APs and Clients. If we click on either rogue AP, suspected rogue or interfering APs and select one of the BSSID followed by clicking on locate button. A pop up window appears and displays "no matches found". This is only noticed after upgrading to 6.4.3.x and prior to this all versions would display the access point which has located the device.
In 6.4.3 WMS, we have disabled the writing of location data to the database. It is disabled by default, and can be enabled by toggling the stat-update parameter in the IDS WMS General profile.
show ids wms-general-profile
IDS WMS General Profile
Parameter                                    Value
AP poll interval                             60000 msec
AP poll retries                              2
AP ageout interval                           30 minutes
Adhoc AP ageout interval                     5 minutes
Station ageout interval                      30 minutes
Statistics update                            false
Persistent Neighbor APs                      true
Persistent Valid STAs                        false
AP learning                                  false
Propagate Wired Macs                         true
Collect Stats for Monitored APs and Clients  false
Learn System Wired Macs                      false
To enable via CLI, please execute the below command-
(Aruba) (config) #ids wms-general-profile
(Aruba) (IDS WMS General Profile) #stat-update
To verify, execute the below command-
Parameter                                    Value
AP poll retries                              2
Statistics update                            true
AP learning                                  false
