Error while upgrading Master Console to 6.1
By JuliaOstrowski posted Jun 09, 2014 12:44 PM
It's possible to get an error like the one below when you're upgrading MC to 6.1.0 or 6.1.1 (a fix exists in 6.1.2). If you see this error, you can finish the upgrade wtih these 2 commands:
# echo "delete from mc_ap_search_results" | db
# root; make
There is absolutely no risk in running these commands, even on a regular AMP.
This is the error:
ERROR: invalid input syntax for integer: "-": update mc_ap_search_results set ap_sysuptime = cast(device_config_uptime as bigint) () at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 191
Mercury::DB::Q::execute('Mercury::DB::Q', 'update mc_ap_search_results set ap_sysuptime = cast(device_co...') called at /usr/local/airwave/lib/perl/Mercury/UpdateDB/1218756157.pmline 82
Mercury::UpdateDB::1218756157::action('Mercury::UpdateDB::1218756157') called at /usr/local/airwave/lib/perl/Mercury/UpdateDB/Base.pm line 32
Mercury::UpdateDB::Base::__ANON__() called at /usr/local/airwave/lib/perl/Mercury/Utility/ChangeDB.pm line 651
Mercury::Utility::ChangeDB::__ANON__() called at /usr/local/airwave/lib/perl/Mercury/Utility/ChangeDB.pm line 528
Mercury::Utility::ChangeDB::modify_database('CODE(0xa4f9314)', 'CODE(0xa4f9394)') called at /usr/local/airwave/lib/perl/Mercury/Utility/ChangeDB.pm line 654
Mercury::Utility::ChangeDB::_schema_change('Change device_config_uptime to ap_sysuptime in ap_list_cache', 'CODE(0xa7237a4)') called at /usr/local/airwave/lib/perl/Mercury/Utility/ChangeDB.pm line 607
Mercury::Utility::ChangeDB::__ANON__() called at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 318
eval {...} called at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 317
Mercury::DB::Q::_run_then_do('Mercury::DB::Q', 'CODE(0xa4f9224)', 'CODE(0xa4f92a4)') called at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 289
Mercury::DB::Q::run_in_transaction('Mercury::DB::Q', 'CODE(0xa4f9224)') called at /usr/local/airwave/lib/perl/Mercury/Utility/ChangeDB.pm line 608
Mercury::Utility::ChangeDB::schema_change('Change device_config_uptime to ap_sysuptime in ap_list_cache', 'CODE(0xa7237a4)') called at bin/update_db.pl line 53
at /usr/local/airwave/lib/perl/Mercury/DB/Q.pm line 325
make: *** [updatedb] Error 255
# root; make
This is the error:
#AP-300
#AP325
