Amigopod & Cisco integration: Post-Authentication redirect incorrect
By Arunkumar posted Jun 26, 2014 12:05 PM
Symptoms: Guests are redirected to the incorrect page after completing a successful captive portal login via Amigopod.
Explanation of problem:
Cisco WLCs may contain a hidden configuration option for a Custom Redirect URL. Normally this feature is utilized in conjunction with the internal Cisco captive portal web login but may override the external redirect if it remains configured.
NOTE: Actual behavior may VARY depending on version of WLC code. You can verify the status of this field by viewing it on the CLI or switching to "internal" web auth type and the field should be revealed in the GUI.
(Cisco Controller) >show custom-web all
Radius Authentication Method..................... PAP
Cisco Logo....................................... Enabled
CustomLogo....................................... None
Custom Title..................................... None
Custom Message................................... None
Custom Redirect URL.............................. http://www.google.com
Web Authentication Type.......................... External
External Web Authentication URL.................. https://10.162.110.13/cisco_web_auth.php
External Web Server list
