How can I troubleshoot split tunnel problems?
By Arunkumar posted Jul 09, 2014 04:28 PM
Product and Software: This article applies to all Aruba controllers and ArubaOS 3.x.
Problem 1
When any user associates with a split tunnel mode SSID, the client will not show up in the "show user" table of the controller because it is a remote user that will terminate at the AP itself.
To find out which role the user is put is, issue the following command:
(Aruba2400) #show datapath user ap-name ap70-sriram
Datapath User Table Entries
Flags: P - Permanent, W - WEP, T- TKIP, V - ProxyArp for User, A - ProxyARP to User, N - VPN
       IP              MAC           ACLs    Contract   Location  Age  Sessions   Flags
0.0.0.0          00:04:23:4A:F9:6E    32/0      0/0     2         0      0/65535  P
10.168.8.221     00:04:23:4A:F9:6E    32/0      0/0     2         0     29/65535    ==========>10.168.8.221 is the user's ip address
10.100.101.74    00:0B:86:C5:A2:12  2700/0      0/0     0         0      1/65535  P
(Aruba2400) #show datapath acl 32
Datapath ACL 32 Entries
1:  any  any  17 0-65535 67-68  P
2:  user  10.168.8.0 255.255.248.0  any  P
3:  any  any  any  PSR
(Aruba2400) #show acl acl-table | include 32
15   session  32         2          https-acl          0
30   session  74         3          h323-acl           0
32   role     296        4          rap-user           0
AclTable
ACL  Type     ACE Index  Ace Count  Name               Applied
31   role     94         2          default-vpn-role   0
33   role     100        14         voice              0
34   role     120        2          authenticated      0
35   role     122        10         stateful           0
(Aruba2400) #show rights rap-user
Priority  Source  Destination  Service   Action         TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan
1         any     any          svc-dhcp  permit                                  Low
2         user    corp         any       permit                                  Low
3         any     any          any       route src-nat                           Low
Problem 2
When the user does not do 802.1x or MAC authentication, that is, the user is doing static WEP, WPA PSK, you must configure the "initial role" in the aaa profile as the split-tunnel role. User derivation rule will not work for remote user.
(Aruba2400) #show aaa profile sriram-aaa-profile
AAA Profile "sriram-aaa-profile "
Parameter                           Value
Initial role                        rap-user    (rap-user is the split tunnel role)
MAC Authentication Profile          N/A
MAC Authentication Default Role     guest
MAC Authentication Server Group     default
802.1X Authentication Profile       sriram-dot1x-profile
802.1X Authentication Default Role  default
802.1X Authentication Server Group  sriram-server-group
RADIUS Accounting Server Group      N/A
User derivation rules               N/A  =====> derivation rule wont work for split tunnelling user
Wired to Wireless Roaming           Enabled
Problem 3
To verify if split tunnel is working, you can send traffic to the "corp" network and the traffic should show up in the "show datapath session table". When you send traffic to any other network, no sessions should appear in the session table.
Problem 4
Split tunnel users will still get IP address through the tunnel from the controller side, not from the RAP local network. You can tell this from the first rule of split tunnel role "any any svc-dhcp permit".
