Requirement:Aruba 2930F Switch running firmware version WC.16.10.0003
Solution:The link-state advertisement (LSA) is a message type of the OSPF routing protocol for the Internet Protocol (IP). It communicates the router's local routing topology to all other local routers in the same OSPF area. Enabling debugging for OSPF lsa-generation will display these messages.
Configuration:Rack2sw1# debug destination session
Rack2sw1# debug ip ospf lsa-generation
Rack2sw1# show debug
Debug Logging
Source IP Selection: Outgoing Interface
Origin identifier: Outgoing Interface IP
Destination:
Session
Time-stamp: System-Uptime
Enabled debug types:
VerificationIn the following debug output, the link state 11.11.11.11 is received from the Router-ID 1.1.1.1 and an acknowledgement sent.
0001:01:22:30.88 OSPF eRouteCtrl:OSPF SEND: 192.168.12.2 -> 224.0.0.5: Version 2, Type LS Acknowledgement (5), Length 44 ret 80
0001:01:22:31.02 OSPF eRouteCtrl: Router ID 2.2.2.2, Area 0.0.0.0, Authentication <MD5> (2)
0001:01:22:31.12 OSPF eRouteCtrl: Zero: 0, Key ID: 1, Length: 16, Sequence: 0
0001:01:22:31.20 OSPF eRouteCtrl: AEX: Advrt 1.1.1.1 LSID 11.11.11.11 Age 6 Sequence 8000000b CkSum 3737 Length 36 Options <E DC>
Rack2sw2# show ip ospf external-link-state link-state-id 11.11.11.11
OSPF External LSAs
Link State ID Router ID Age Sequence # Checksum
11.11.11.11 1.1.1.1 248 0x8000000b 0x00003737
