If you are upgrading according to any of these paths:
6.2rc4 beta --> 6.2 General beta
6.2 General beta --> 6.2 general release
6.2rc4 beta --> 6.2 general release
Your upgrade may fail with this message:
/root/AMP-6.2.0_beta4-amp_upgrade: line 3: syntax error near unexpected token `newline'
/root/AMP-6.2.0_beta4-amp_upgrade: line 3: ` <head>'
There is a typo in the upgrade script that generates an incorrect file path. To apply the fix:
1. Ssh into your AMP server as root
2. Enter the scripts directory
# scripts
3. Within the scripts directory, there is a script called start_amp_upgrade. This file contains a one-letter typo that must be fixed using VI or another text editor. If you're unfamiliar with editing files in Linux, contact support@airwave.com for assistance.
The typo is on line 110:
$TARGET_fILE
should be
$TARGET_FILE
**note the change between lowercase "f" and capital "F"
After saving the file run ml from the AMP command line. When the make is done, run the upgrade command again:
# start_amp_upgrade -v 6.2.0_beta3
# scripts
$TARGET_fILE
should be
$TARGET_FILE
# scripts
$TARGET_fILE
should be
$TARGET_FILE
