Is it possible to change the Group's password on Aruba Central
By esupport posted Mar 29, 2017 03:28 PM
Q:
When a new Group is created on Aruba Central, it will ask to enter a default password for the device which would be provisioned later. Is there a way to change it?
A:
The Group password is same as Management authentication password. We can change the password for "admin" user and the same will be replicated to all VCs/IAPs in the group.
We can change it under - Network Management - System - Authentication
1 comment
Comments
Jan 09, 2020 06:36 PM
it doesn't look like this at all in aruba central?
it does in the new aruba-central interface though
