Pre-provisioning VLAN in MAS using GVRP
By Srynearson posted May 29, 2014 05:32 PM
GVRP
(GARP VLAN Registration Protocol or Generic VLAN Registration Protocol) is a
protocol that facilitates control of virtual local area networks (VLANs) within a larger network . GVRP conforms to the IEEE 802.1Q specification, which defines a method of tagging frames with VLAN configuration data. This allows network devices to dynamically exchange VLAN configuration information with other devices.
GVRP in MAS and IAP
When you create an SSID on the IAP, you can also associate a VLAN tag with that SSID. The IAP can then share that VLAN tag with the Mobility Access Switch so that you do not need to pre-provision the VLAN ID on the MAS. This makes it easier to build out new SSIDs as needed without having to touch the wired infrastructure.
Config
interface-profile switching-profile "TRUNK"
   switchport-mode trunk
interface-profile poe-profile "poe-factory-initial"
   enable
interface-profile lldp-profile "lldp-factory-initial"
   lldp transmit
   lldp receive
   med enable
interface-profile gvrp-profile "IAP-MAS"
   enable
gvrp
   enable
interface gigabitethernet "0/0/2"
Troubleshooting Output
show vlan
(host) #show vlan
VLAN CONFIGURATION
VLAN  Description  Ports
1     VLAN0001     GE0/0/0-23 GE0/1/0-1
500   GVRP VLAN    GE0/0/2
510   GVRP VLAN    GE0/0/2
520   GVRP VLAN    GE0/0/2
show gvrp interfaces
(host) # show gvrp interfaces
Interface GVRP info
Interface             State    Registrar Mode
gigabitethernet0/0/2  Enabled  Normal
1 view
