HPE/Aruba-OS 5400R zl2 Switch - How To Find The Part Number And Serial Number For Power Supplies
By esupport posted Jul 26, 2020 12:23 PM
Q:
How can I find the product number and/or serial number for the power supplies installed in my 5400R zl2 switch?
A:
To view the part number and serial number of any installed power supplies on the 5400R zl2 switch, use the following command at the switch CLI:
  show system power-supply
  This output shows an example of a 5406R zl2 switch with one power supply installed:
If you need to view additional status details about the power supply, add the "detail" option at the end of the command:
  show system power-supply detail
  This output shows the same 5406R zl 2 switch with the "detail" option included:
