How to restrict SSH access to the controller to a particular host / subnet?
By esupport posted Feb 23, 2017 06:50 PM
To Limit SSH access to controller interfaces.
SSH access to an Aruba controller requires valid credentials which includes username and password. However an attacker can run a script to enter multiple SSH requests with changing username / password pair. To prevent this, we can limit SSH access to the controller from a few subnets / hosts.
We can use Service ACL also known as firewall-cp for this. Default configuration for this is given below.
#show firewall-cp
CP firewall policies
IP Version  Source IP  Source Mask  Protocol  Start Port  End Port  Permit/Deny  hits  contract
ipv4        any                     17        1900        1900      Permit       0
ipv4        any                     17        5999        5999      Permit       0
With Service ACL , we can put restrictions on the traffic hitting the controller. These ACLs will allow / prevent access to all the controller IP interfaces.
Here, we will restrict the SSH access to the controller to a host with an ip address 10.1.1.100
(config) #firewall  cp
(config-fw-cp) #ipv4 permit host 10.1.1.100 proto ssh
(config-fw-cp) #ipv4 deny any proto ssh
We can see the service ACL after the config:
(Aruba3600) (config-fw-cp) #show firewall-cp
ipv4        10.1.1.100  255.255.255.255  6         22          22        Permit       0
ipv4        any                          6         22          22        Deny         0
1. When we try to SSH to the controller from any other IP , the service ACL will block it. Below we initiate a SSH session from 10.1.1.247 which is dropped:
(config-fw-cp) #show datapath session table 10.1.1.247
Source IP       Destination IP  Prot SPort DPort Cntr  Prio ToS Age Destination TAge Packets    Bytes      Flags
10.1.1.247      10.1.1.5        6    36013 22     0/0  0    0   0   1/0         2    0          0          FDYC
2. We can also see the counters increase on the firewall-cp for deny ACL:
ipv4        any                          6         22          22        Deny         6
3. When we initiate a session from the permitted host 10.1.1.100, we no longer see D flag:
(Aruba3600) (config-fw-cp) #show datapath session table 10.1.1.100
10.1.1.100      10.1.1.5        6    48671 22     0/0  0    0   1   1/0         9    12         1244       C
10.1.1.5        10.1.1.100      6    22    48671  0/0  0    4   1   1/0         9    10         1640
4. Also we see the counters increase in firewall-cp for permit ACL:
ipv4        10.1.1.100  255.255.255.255  6         22          22        Permit       27
ipv4        any                          6         22          22        Deny         7
