Sometimes we can come across issue where Airwave server is not booting up and we will see the below error during the boot.
The reason for this error is one of the partition would have corrupted blocks. Scenarios we would see this kind of behavior is when there was a power outage or if the instance was not shutdown properly, which would have lead to file corruption.
To fix this issue we would have to do a file system check on the server. If we are on a version prior to 8.2.4 we can do it from single user mode, else we have to do it from Linux rescue mode. Doing the file system check as single user
umount / fsck -f -y /dev/VolGroup00/LogVol00 reboot Doing the file system check from Linux rescue To do this first mount the ISO for Airwave or centos to the server. When it boots up with the ISO on the boot prompt type "Linux rescue" boot: linux rescue Once done run the below commands for doing an LVM scan if you have used Linux LVM to create your partition lvm pvscan lvm vgscan lvm lvchange -ay VolGroup00 lvm lvscan Once done we can umount "/" so that we can do the file system check chroot /mnt/sysimage umount / We can execute the below command to do the file system check fsck -f -y /dev/VolGroup00/LogVol00 Once done we can reboot the server using the below command, reboot Now the server should be booting up fine.
© Copyright 2021 Hewlett Packard Enterprise Development LPAll Rights Reserved.
