AppRF - supported application list
By AnandKumar Sukumar posted Jun 29, 2014 05:18 PM
How to verify the list of supported applications for AppRF classification?
Environment : AOS controller running 6.4 or higher code.
AppRF is an Application Aware Deep packet inspection technology introduced by Aruba.
This feature is supported starting from AOS 6.4.
To verify the list of Applications that will be categorized under this below command can be run. This list will be updated in each release. To get the updated list, run the below command on your controller.
(Abilash-Lab-Cont-master-6.4) #show dpi application all
Applications
Name               App ID  App Category         Default Ports               Applied
01net              948     web                  tcp 80                      0
050plus            1123    audio-video          tcp 80 443                  0
0zz0               584     web                  tcp 80                      0
10050net           1339    web                  tcp 80                      0
10086cn            949     web                  tcp 80 443                  0
104com             1336    web                  tcp 80                      0
1111tw             1338    web                  tcp 80                      0
114la              950     web                  tcp 80                      0
115com             951     web                  tcp 80 443                  0
118114cn           952     web                  tcp 80                      0
11st               1191    web                  tcp 80                      0
123people          953     web                  tcp 80                      0
163com             1242    web                  tcp 80                      0
17173com           1340    web                  tcp 80                      0
17u                1341    web                  tcp 80                      0
2ch                1316    web                  tcp 80                      0
2shared            266     web                  tcp 80                      0
360buy             1248    web                  tcp 80                      0
360cn              1255    web                  tcp 80                      0
3gpp-li            1437    tunneling                                        0
3pc                606     network-service                                  0
4399com            1269    web                  tcp 80                      0
4shared            267     web                  tcp 80                      0
51job              1278    web                  tcp 80                      0
51la               1277    web                  tcp 80                      0
56com              1259    web                  tcp 80                      0
58com              1257    web                  tcp 80                      0
591tw              1337    web                  tcp 80                      0
7k7k               1342    web                  tcp 80                      0
802-11             1290    network-service      udp 5246-5247               0
8021q              7       network-service                                  0
91com              1335    web                  tcp 80                      0
9game              1343    web                  tcp 80                      0
abcnews            954     web                  tcp 80                      0
about              955     web                  tcp 80                      0
accuweather        956     web                  tcp 80                      0
acer               957     web                  tcp 80                      0
acrobat            958     web                  tcp 80 443                  0
zoho-db           882     web                tcp 80 443     0
zoho-im           883     instant-messaging  tcp 80 443     0
zoho-meeting      884     web                tcp 80 443     0
zoho-notebook     1490    web                tcp 80 443     0
zoho-people       885     web                tcp 80 443     0
zoho-planner      1491    web                tcp 80 443     0
zoho-share        1492    web                tcp 80 443     0
zoho-sheet        1493    web                tcp 80 443     0
zoho-show         1494    web                tcp 80 443     0
zol               1262    web                tcp 80         0
zonealarm-update  754     antivirus          tcp 80 443     0
zoo               522     web                tcp 80         0
zshare            315     web                tcp 80         0
zum               1198    web                tcp 80         0
zynga             1285    web                tcp 80         0
Total applications = 1415
1 comment
Comments
Jul 03, 2014 12:22 AM
I do not have the controller which I can evaluate now.
When possible, would you attach a full list of the application in txt?
I want to check whether the application used well in Japan is applicable.
Thank you
