ArubaOS-Switch – Error Message 05404 userTnode, 05402 userTnode: and 05405 userTnode: Reported
By esupport posted Apr 21, 2020 05:38 PM
Problem:
The following messages are being reported in the log file.
I 04/17/20 13:56:46 05404 userTnode: Node List  event received from Switch
            Anchor Controller (SAC) 10.0.10.2.
I 04/17/20 13:56:46 05405 userTnode: Anchor controller 10.0.10.4 is down.
I 04/17/20 13:57:13 05402 userTnode: Switch Anchor Controller (SAC) is
            10.0.10.4.
Diagnostics:
When IP connectivity is lost between the SAC (Switch Anchor Controller) and the ArubaOS-Switch, the SAC event messages is reported.
In the following example, the tunnel node server state is display and then IP connectivity loss occurs. The mobility controller using the IP address 10.0.10.2 is the SAC. After IP connectivity is lost, the mobility controller using the IP address 10.0.10.4 becomes the SAC.
Core-Switch# show tunneled-node-server state
 Local Master Server (LMS) State
 LMS Type     IP Address       State        Capability Role
 Primary   :  10.0.10.2        Complete     Per User   Operational Primary
 Secondary :  10.0.10.4        Complete     Per User   Operational Secondary
 Switch Anchor Controller (SAC) State
                          IP Address       Mac Address               State
 SAC                 : 10.0.10.2        000b86-b73497           Registered
 Standby-SAC : 10.0.10.4        204c03-035b88            Registered
 User Anchor Controller (UAC) : 10.0.10.2
 User              Port       VLAN       State       Bucket ID
 User Anchor Controller (UAC) : 10.0.10.4
I 04/17/20 13:56:49 05404 userTnode: Node List  event received from Switch
I 04/17/20 13:56:55 05405 userTnode: Anchor controller 10.0.10.2 is down.
I 04/17/20 13:57:13 05405 userTnode: Anchor controller 10.0.10.2 is down.
            10.0.10.4.
Solution
Determine the cause of the lost IP connectivity.
