create cron jobs to run scripts
By JuliaOstrowski posted Jun 06, 2014 06:35 PM
In this example we use ignore_rogues_by_ssid_wildcard.pl .
Here are instructions for adding the ignore rogue script to crontab
1. Edit the crontab file to add the script
#crontab -e
Add the following line: (to run the script at 9 am)
0 09 * * * /var/airwave/custom/ignore_rogues_by_ssid_wildcard.pl /var/airwave/custom/input.csv ( full path to input .csv file) (save and exit just like vi)
2. Restart the crond service to apply the changes
#service crond stop
#service crond start
Here is more examples on the crontab file format:
In the example below the script gets executed every day at 9 am:
# minute (0-59),
# | hour (0-23),
# | | day of the month (1-31),
# | | | month of the year (1-12),
# | | | | day of the week (0-7 with 0=7=Sunday).
# | | | | | command(s)
0 9 * * * /var/airwave/custom/ignore_rogues_by_ssid_wildcard.pl /var/airwave/custom/input.csv
