How to test a cable connected to a port from Aruba MAS?
By esupport posted Mar 26, 2017 07:02 AM
If the cable connected to the switch port is bad and in order to test the cable connectivity between the end devices.
We can run the diagnostics on the ports of Aruba Mobility Access Switches to check the connectivity of the cable with end devices.
(Switch2500) #run diagnostics interface gigabitethernet 0/0/1 cable
TDR started on interface gigabitethernet0/0/1
(Switch2500) #show  diagnostics interface gigabitethernet 0/0/1 cable
Interface name        : gigabitethernet0/0/1
Test status           : Completed
Normal cable length    : 55 metres
Pair 1-2
Pair status        : Normal
Polarity swap        : Positive
Pair skew        : 16
Pair 3-6
Pair skew        : 16
Pair 4-5
Pair skew        : 0
Pair 7-8
Pair skew        : 16
Channel 0:
Pair swap        : Straight
Channel 1:
(Switch2500) #
1 comment
Comments
Sep 08, 2017 02:10 PM
What is the unit of measure that "Pair skew" is reporting?
