How to delete AP stale entries in Aruba Mobility Controller in the role of "Local"?
By esupport posted Mar 20, 2017 05:53 PM
Aruba Mobility Controllers should be running Minimum ArubaOS 6.5.0.1 or above
When an AP terminates on a controller and moves to another controller, or an AP is removed from the WLAN network, a stale entry of the AP continues to remain in the AP database of the controller. The controller might be a Master or Local controller.
Prior to 6.5.0.1 a stale entry of the AP can be deleted only in the "Master" Controller. When we try to delete the stale entry from a "Local" controller we get the following error message ""This command must be run on the active master""
Starting from ArubaOS 6.5.0.1, a stale entry of the AP in the "Local" controller can be deleted.
From CLI:
Syntax:
(Local) #clear gap-db stale-ap ap-name/wired-mac <ap-name/ap-wired-mac-address> lms lms-ip/lms-ip6 <ipv4/ipv6 ip-address>
Example
(Local) #clear gap-db stale-ap ap-name AP225 lms lms-ip 10.17.169.151
From WebUI:
At the moment this option is available only from CLI and not available from WebUI.
Verification with an Example:
Before the execution of the command:
(Local) #show ap database long
AP Database
Name               Group       AP Type  IP Address     Status  Flags  Switch IP      Standby IP  Wired MAC Address  Serial #   Port  FQLN  Outer IP  User
24:de:c6:cf:81:36  Aruba-Test  215      10.17.169.158  Down    2      10.17.169.151  0.0.0.0     24:de:c6:cf:81:36  CK0005594        N/A   N/A
AP225              Aruba-Test  225      10.20.25.34    Down    2      10.17.169.151  0.0.0.0     9c:1c:12:c1:41:8e  BX0061358        N/A   N/A
Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
       I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
       X = Maintenance Mode; P = PPPoE AP; B = Built-in AP; s = LACP striping
       R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
       c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
       u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
       i = Indoor; o = Outdoor
       M = Mesh node; Y = Mesh Recovery
Port information is available only on 6xx.
Total APs:2
(Local) #
After the Execution of the command
AP Database
Total APs:1
(Local) #
2 comments
Comments
Jun 21, 2018 03:08 PM
Command doesn't work in 8.0
Apr 20, 2018 12:47 PM
I can't seem to clear the AP out of MM, does this not work on AOS8?
