IAP to rap apboot conversion
By Shyam_Moolayilkalarikkal posted Jun 30, 2014 05:34 PM
Question: How to convert an IAP to Remote AP from apboot?
                   How to convert a single IAP from a cluster to Remote AP?
Environment: Aruba Instant at remote site which needs to deployed as RAP terminating to an Aruba Controller. Ensure Controller end configuration is in place (i.e. RAP whitelist entry; RAP inner IP pool)
Conventional option to convert an Instant AP to Remote AP is  via Activate or Instant User Interface. However; there maybe instances (such as high security  environment; convert one AP from existing cluster) where it would be desirable to carry out the conversion via apboot. This article walksthrough the procedure to carry out IAP to Remote AP conversion via apboot.
Break the boot sequence and enter apboot> mode.
APBoot 1.2.6.7 (build 30025)
Built: 2011-08-30 at 17:41:16
Model: AP-13x
CPU:   88F6560 A0 (DDR3)
Clock: CPU 1600MHz, L2 533MHz, SysClock 533MHz, TClock 200MHz
DRAM:  256MB
POST1: mem 0 mem 1 mem 2 mem 3 passed
Flash: 16 MB
Power: 802.3at POE
LAN:   done
PHY:   ....done
PEX 0: RC, link up, x1
       bus.dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
       00.00   00  11ab  6560 00005   02 f1000000 00000000 00000000 00000000
       00.01   00  168c  0030 00002   01 90000000 00000000 00000000 00000000
PEX 1: RC, link up, x1
       01.00   00  11ab  6500 00005   02 f1000000 00000000 00000000 00000000
       01.01   00  168c  0030 00002   01 94000000 00000000 00000000 00000000
Net:   eth0, eth1
Radio: ar9390#0, ar9390#1
Hit <Enter> to stop autoboot:  2
apboot>
Execute printenv to ensure there is no static configuration already and make note of the bootfile name.
apboot> printenv
bootdelay=2
baudrate=9600
autoload=n
boardname=Arran
servername=aruba-master
bootcmd=boot ap
autostart=yes
bootfile=armv5te.ari
ethaddr=6c:f3:7f:c4:0b:6a
os_partition=0
As Aruba Instant has Instant OS; we would need to configure serverip pointing to the Master Controller to which the AP would terminate.
apboot> setenv serverip 10.17.225.120
apboot> saveenv
Execute command  upgrade os command in below format (matching bootfile value present in printenv) to convert as Controller-based AP.
apboot> upgrade os armv5te.ari
eth0: up, 1 Gb/s, full duplex
DHCP broadcast 1
DHCP IP address: 10.17.225.125
DHCP subnet mask: 255.255.255.224
DHCP def gateway: 10.17.225.126
DHCP DNS server: 8.8.8.8
DHCP DNS domain: arubatac.local
Controller address: 10.17.225.100
Using eth0 device
TFTP from server 10.17.225.120; our IP address is 10.17.225.125
Filename 'armv5te.ari'.
Load address: 0x2000000
Loading: *#################################################################
done
Bytes transferred = 5078596 (4d7e44 hex)
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
Erasing flash sector @ 0xf8100000.................................................................................done
Erased 78 sectors
Copying to flash...
Writing .............................................................................done
Verifying flash... 5078596 bytes were the same
Upgrade successful.
If dynamic master discovery isn't possible; assign static Master IP.
apboot> setenv master <ip of master>
apboot> saveenv
Configure variable to make the AP as Remote AP (without this step; AP would come as Campus AP),
apboot> setenv remote_ap 1
apboot> saveenv
Execute boot for the AP to boot up and come as Remote AP and confirm the AP has Controller's code version.
apboot> boot
Booting OS partition 0
Checking image @ 0xf8100000
Copying image from 0xf8100000
Signer Cert OK
Policy Cert OK
## Booting image at 02000200 ...
Uncompressing... done
Aruba Networks
ArubaOS Version 6.3.0.0 (build 38660 / label #38660)
Built by p4build@cyprus on 2013-06-12 at 20:14:01 PDT (gcc version 4.3.3)
Memory: 256MB = 256MB total
Memory: 243840KB available (2816K code, 9017K data, 3852K init, 0K highmem)
Confirmation from Controller.
(controller-A) # show ap database long
AP Database
Name               Group  AP Type  IP Address  Status    Flags  Switch IP      Standby IP  Wired MAC Address  Serial #   Port  FQLN  Outer IP       User
6c:f3:7f:c4:0b:6a  Test   135      1.1.1.2     Up 1m:3s  Rc2    10.17.225.120  0.0.0.0     6c:f3:7f:c4:0b:6a  AX0162838  N/A   N/A   10.17.225.125
