Skip to main content (Press Enter).
Register | Sign in
Skip auxiliary navigation (Press Enter).
Skip main navigation (Press Enter).
Toggle navigation
Discussion
Support
Technical Product Details
Community Learning
News
Events
Search
Blog Viewer
Configuring OpenDNS on Aruba Mobility Controller
By
OpenDNS
posted
Dec 20, 2011 04:55 PM
Options Dropdown
Mark as Inappropriate
0
Kudos
OpenDNS can be used across a wide variety of networks. Since DNS is a common layer shared by any type of network, configuration is simple no matter the complexity of your network topology. The attached guide focuses on configuring your VLAN's DHCP settings in Aruba Campus WLAN OS version 6.0.1.x to point to the OpenDNS IPs (209.67.222.222, 208.67.220.220)
If you're using an internal DNS server let us know what you're using (BIND, Windows Server, etc.) and we'll put together instructions that are more specific to your deployment.
For more information, please visit
www.opendns.com
Open dns configuring opendns on aruba controller
from
AirheadsSocial
OpenDNS - Configuring OpenDNS on Aruba Controller.pdf
Reason for Moderation
Describe the reason this content should be moderated (required)
Privacy policy
Terms of service
Site Map
Legal
© Copyright 2021 Hewlett Packard Enterprise Development LP
All Rights Reserved.
Powered by Higher Logic
