How do I check the transmit and receive data rate on a mesh network?
By Shyam_Moolayilkalarikkal posted Jul 03, 2014 05:01 PM
Question:  How do I check the transmit and receive data rate on a mesh network?
Product and Software: This article applies to all Aruba controllers and Aruba OS 3.3.1.
The mesh point will associate to the parent mesh node using either the radio a or b/g to establish the wireless backhaul connection to the wired networks.
To check the transmit rate, receive rate, last received Signal to Noice Ratio (SNR), and last ACK SNR, follow these steps:
Step 1:
Identify the name of the parent node for the mesh point using the following command:
(STU2) #show ap mesh topology
Example:
The parent AP name for point:9c is portal:be
(STU2) #show ap mesh topo Mesh Cluster Name: stu2-mesh
Name Mesh Role Parent Path Cost Node Cost Link Cost Hop Count RSSI Last Update Uplink Age #Children
point:9c Point portal:be 1 0 0 1 32 4m:29s 26m:26s 0
portal:36 Portal - 0 0 0 0 0 3m:34s 3h:26m:34s 0
portal:be Portal - 0 1 0 0 0 27s 3h:26m:25s 1 Total APs :3
(R): Recovery AP. For Portals 'Uplink Age' equals uptime.
Step 2:
Get the client data using the following command:
show ap debug client-table ap-name <name>
Example:
Tx rate : 36 Mbps
Rx rate : 48 Mbps
Last ACK SNR : 32
Last RX SNR: 26
(STU2) #show ap debug client-table ap-name portal:be
Client Table
MAC ESSID BSSID Assoc_State HT_State AID PS_State UAPSD Tx_Pkts Rx_Pkts PS_Pkts Tx_Retries Tx_Rate Rx_Rate Last_ACK_SNR Last_Rx_SNR Tx_Timestamp Rx_Timestamp
00:0b:86:e2:c9:d1 stu2-mesh 00:0b:86:8b:7b:e8 Associated None 0x1 Awake (0,0,0,0) 935 1455 0 271 36 48 32 26 Fri Jul 4 14:18:30 2008 Fri Jul 4 14:18:30 2008
