Redirecting users to a desired welcome page without any authentication on the Captive portal
By esupport posted May 20, 2015 07:36 AM
How to redirect users to a desired welcome page without any kind of authentication on the Captive portal?
<html>
//test.html
<head>
</head>
<form name="loadportal" FORM method="post" ACTION="/auth/index.html/u">
<INPUT type="hidden" name="user" accesskey="u" SIZE="25" VALUE="test">
<INPUT type="hidden" name="password" accesskey="p" SIZE="25" VALUE="test123">
<input type="submit" name="inputme" value="Submit" style="visibility:hidden">
</form>
<script>
 window.onload = function()
document.loadportal.submit();
</script>
</html>
Below are the steps and use the appended “test.html” for reference.
Step:1
Create a Test captive portal profile and do the below changes:
Upload the “test.html” to the test captive portal profile on the controller.
aaa authentication captive-portal "Test"
default-role "authenticated"
redirect-pause 0
no logout-popup-window
logon-wait maximum-delay 4
login-page "/upload/custom/test.html"
welcome-page http://www.arubanetworks.com
Step:2
Need to create a “Test” initial role:
user-role Test_initial
session-acl logon-control
session-acl captiveportal
Step:3
Need to create a “Test” server-group with the authentication server as internal, add a username: test and password: test123 in the internal DB as in the script.
Step: 4
Map the captive portal profile, server group and initial role to the “Test” aaa profile:
aaa profile "Test"
initial-role "Test_initial"
dot1x-server-group "Test"  ----------------Need to map it to the dot1x-server-group.
Connect to the ssid, open up the browser and try typing any website address and you will be redirected to "www.arubanetworks.com" here as in the welcome page url.
