Requirement:Aruba APs can monitor the other APs in the RF environment and classify them as valid, Interfering, rogue, or suspected-rogue. Sometimes we may need to manually re-classify a monitored AP.
How to manually re-classify a monitored AP as valid, Interfering, rogue, suspected-rogue, manually-contained or neighbor in Instant?
Solution:We can manually re-classify a monitored AP by specifying the phy_type and rap_type. Below are the different phy_type and rap_type values.
Rajaguru-IAP# show ids phy-types
Physical Types
Keyword Value
b 0
a 1
g 2
ag 3
Rajaguru-IAP# show ids rap-types
RAP Types
Keyword Value
valid 0
interfering 1
rogue 2
dos-attack 3 (Manually contained)
unknown 4
known-interfering 5 (Neighbor)
suspect-rogue 6
Configuration:The command to manually re-classify a monitored AP is:
Rajaguru-IAP# ids-reclassify ap <monitored-AP-bssid> <phy_type> <rap_type>
VerificationBelow is an example of re-classifying an AP to a different type.
Rajaguru-IAP# show ap monitor ap-list | include testssid
18:64:72:19:76:c0 testssid 11 interfering 80211b/g-HT-20 disable 116215/45805 25/1 wpa2-psk-aes 0 0 54 0 41 0 no 58151
18:64:72:19:76:d0 testssid 149 interfering 80211a-VHT-80 disable 115190/12283 6/0 wpa2-psk-aes 0 0 60 0 35 0 no 0
Rajaguru-IAP#
Rajaguru-IAP# ids-reclassify ap 18:64:72:19:76:c0 0 2
Rajaguru-IAP# ids-reclassify ap 18:64:72:19:76:d0 1 2
Rajaguru-IAP#
18:64:72:19:76:c0 testssid 11 rogue 80211b/g-HT-20 enable 116293/45806 21/2 wpa2-psk-aes 0 0 54 0 41 0 no 58151
18:64:72:19:76:d0 testssid 149 rogue 80211a-VHT-80 enable 115268/12284 1/0 wpa2-psk-aes 0 60 60 35 35 0 no 0
Rajaguru-IAP#
Rajaguru-IAP# ids-reclassify ap 18:64:72:19:76:c0 0 5
Rajaguru-IAP# ids-reclassify ap 18:64:72:19:76:d0 1 5
Rajaguru-IAP#
18:64:72:19:76:c0 testssid 11 neighbor 80211b/g-HT-20 disable 116420/45903 0/0 wpa2-psk-aes 0 53 55 41 40 0 no 58151
18:64:72:19:76:d0 testssid 149 neighbor 80211a-VHT-80 disable 115395/12285 3/0 wpa2-psk-aes 0 0 60 0 35 0 no 0
Rajaguru-IAP#
Rajaguru-IAP# ids-reclassify ap 18:64:72:19:76:c0 2 3
Rajaguru-IAP# ids-reclassify ap 18:64:72:19:76:d0 1 3
Rajaguru-IAP#
Rajaguru-IAP# show ap monitor ap-list | inc testssid
18:64:72:19:76:c0 testssid 1 manually-contain 80211b/g-HT-20 enable 117090/46181 0/0 wpa2-psk-aes 0 59 57 35 38 0 no 58151
18:64:72:19:76:d0 testssid 149 manually-contain 80211a-VHT-80 enable 116065/12291 66/1 wpa2-psk-aes 0 0 60 0 35 0 no 0
Rajaguru-IAP#
