Problem:The VLAN configuration option "ip-recv-mac-address" causes Ping command to fail.
Diagnostics:The Aruba switch does not respond to Ping command after configuring the ip-recv-mac-address Vlan option.
SolutionIP routing must be enabled when using the ip-recv-mac-address Vlan option. In the following example, Vlan 1 on switch Rack2sw1 is configured for the ip-recv-mac-address option. The Ping test fails until IP routing is enabled.
The configuration, verification, and testing associated with the diagram follows:
Testing with and without IP routing enabled:
Rack2sw1# ping 192.168.2.2
Request timed out.
Rack2sw1(config)# ip routing
192.168.2.2 is alive, time = 2 ms
Vlan configuration:
Rack2sw1# show running-config vlan 1
Running configuration:
vlan 1
name "DEFAULT_VLAN"
untagged A1-A24,B1-B24,C1-C24,D1-D24,F1-F24,J1-J4,K1-K4,L1-L4
ip address 192.168.2.1 255.255.255.0
ip-recv-mac-address 08002b-111111 interval 1
Rack2sw2# show running-config vlan 1
vlan 1
name "DEFAULT_VLAN"
untagged A1-A24,B1-B24,C1-C24,D1-D24,E1-E2,G1-G24,H1-H2,J1-J4,K1-K4,L1-L4
ip address 192.168.2.2 255.255.255.0
Vlan verification:
Rack2sw1# show vlans ports l1 detail
Status and Counters - VLAN Information - for ports L1
VLAN ID Name | Status Voice Jumbo Mode
1 DEFAULT_VLAN | Port-based No No Untagged
Rack2sw2# show vlans ports l1 detail
Physical interconnect:
Rack2sw1# show lldp info remote-device
LLDP Remote Devices Information
LocalPort | ChassisId PortId PortDescr SysName
L1 | 00 18 fe ef a5 00 265 L1 Rack2sw2
Rack2sw2# show lldp info remote-device
L1 | 00 17 08 cd 05 00 265 L1 Rack2sw1
