List of IAP models and the required minimum InstantOS versions
By JuliaOstrowski posted Jun 10, 2014 02:15 PM
Environment   This article applies to Aruba Instant Access Points.
IAP InstantOS software comes with the support for IAP hardware thus enabling these APs to come-up and broadcast the SSID. WLAN administrators need to look for the minimum supported version before downgrading an IAP in the production setup. The below table shows the IAP models and the minimum supported version:
IAP Hardware
IAP Firmware Image Class
Minimum software version Supported
IAP-104/105
Orion
5.0.3.0-1.1.x.x
IAP-134/135
Cassiopeia
6.1.2.3-2.0.x.x
RAP-3WN/3WNP,  IAP-175P/175AC,  IAP-92/93
Orion
6.1.3.1-3.0.x.x
RAP-108/109 & IAP-114/115
Pegasus
6.2.0.0-3.2.x.x   &  6.3.1.1-4.0.x.x
RAP-155
Aries
6.2.1.0-3.3.x.x
IAP-224/225
Centaurus
6.3.1.1-4.0.x.x
#RAP155
4 comments
1 view
Comments
Jun 30, 2017 10:06 AM
hi
in the Airwave Plateform we ve got this message for IAP
Could not find suitable firmware image:6.5.0.0-4.3.0.0_56428(Vela) for ArubaInstant
Usualy I've got the same message with Taurus, lupus, release software witch is very useful to find the IAP  but In my case i ve got  "Vela"  I don't know  the software to download ??
Can you help me
Regards
Jun 07, 2017 08:58 AM
I have been looking for an updated version of this. We have a number of IAP-92/93 APS used for Barcode Scanners, we want to add some more AP's (IAP-207) but I am not sure about the firmware compatability between them.
Apr 28, 2016 08:40 AM
I've found this from the following link: Documentation
This might help others who are seeking image calss names
The following examples describe the image file format for different IAP models:
  1. For IAP-134/135—ArubaInstant_Cassiopeia_6.4.4.4-4.2.3.0.0_xxxx
  2. For RAP-108/109, IAP-103, and IAP-114/115—ArubaInstant_Pegasus_6.4.4.4-4.2.3.0.0_xxxx
  3. For RAP-155/155P—ArubaInstant_Aries_6.4.4.4-4.2.3.0.0_xxxx
  4. For IAP-224/225, IAP-228, IAP-214/215, IAP-274/275, IAP-277 -ArubaInstant_Centaurus_6.4.4.4.4.2.3.0.0_xxxx
  5. For IAP-324/325—ArubaInstant Hercules_6.4.4.4-4.2.3.0.0_xxxx
  6. For IAP-204/205 and IAP-205H—ArubaInstant_Taurus_6.4.4.4-4.2.3.0.0_xxxx
  7. For all other IAPs—ArubaInstant_Orion_6.4.4.4-4.2.3.0.0_xxxx
Kindest regards
J.
Apr 27, 2016 03:46 PM
would you you be able to post the full table with IAP Firmware Image Classes please. We have IAP103 and IAP205s but the table above doesn't show the class name.
kindest regards
J.
