Can the CPPM cluster be formed across firewalled environments
By Shyam_Moolayilkalarikkal posted Jul 02, 2014 07:34 PM
Question   Is it possible to setup CPPM Cluster over a fire wall?
Yes, it is possible to build a cluster even in a firewall environment.
Below are the key points for this.
1: The below ports must be allowed across the cluster.
  • UDP Port 123 NTP (Subscriber to publisher)
  • TCP Port 443 HTTPS (Bi-directional)
  • TCP Port 5432 PostgreSQL for DB replication (Subscriber to publisher)
  • TCP Port 80 HTTP (Between Nodes)
2: Natting is not allowed across the Cluster.
