How Can Ports That Connect To Other Spanning-Tree Switches Be Displayed?
By esupport posted May 29, 2020 09:32 AM
Q:
How can ports that connect to other spanning-tree switches be displayed?
A:
The “Edge” column in the command show spanning-tree output will contain the value “Yes” or “No”.
  • “No” indicates a connection to a switch and
  • “Yes” indicates a connection to a device that does not run spanning-tree protocol.
In the following example;
 • Ports 1-14, 23 and 24 are in an up state.
 • Ports 1-6 and 24 are connected to switches.
 • Ports 7-14 and 23 are connected to devices that do not run spanning-tree protocol.
Rack2sw1# show interfaces brief | exclude Down
 Status and Counters - Port Status
                          | Intrusion                           MDI  Flow Bcast
  Port         Type       | Alert     Enabled Status Mode       Mode Ctrl Limit
   1            100/1000T  | No        Yes     Up     1000FDx    MDI  off  0
   2            100/1000T  | No        Yes     Up     1000FDx    MDIX off  0
   3            100/1000T  | No        Yes     Up     1000FDx    MDIX off  0
   4            100/1000T  | No        Yes     Up     1000FDx    MDIX off  0
   5            100/1000T  | No        Yes     Up     1000FDx    MDI  off  0
   6            100/1000T  | No        Yes     Up     1000FDx    MDIX off  0
   7            100/1000T  | No        Yes     Up     1000FDx    MDIX off  0
   8            100/1000T  | No        Yes     Up     1000FDx    MDI  off  0
   9            100/1000T  | No        Yes     Up     1000FDx    MDIX off  0
  10           100/1000T  | No        Yes     Up     1000FDx    MDIX off  0
  11           100/1000T  | No        Yes     Up     1000FDx    MDI  off  0
  12           100/1000T  | No        Yes     Up     1000FDx    MDI  off  0
  13           100/1000T  | No        Yes     Up     1000FDx    MDI  off  0
  14           100/1000T  | No        Yes     Up     1000FDx    MDI  off  0
  23           100/1000T  | No        Yes     Up     1000FDx    MDIX off  0
  24           100/1000T  | No        Yes     Up     1000FDx    MDI  off  0
Rack2sw1# show spanning-tree | exclude Disable
 Multiple Spanning Tree (MST) Information
  STP Enabled   : Yes
  Force Version : MSTP-operation
  IST Mapped VLANs : 1-4094
  Switch MAC Address : 941882-a48880
  Switch Priority    : 32768
  Max Age  : 20
  Max Hops : 20
  Forward Delay : 15
< some output omitted >
                   |           Prio              | Designated    Hello
  Port  Type       | Cost      rity State        | Bridge        Time                    PtP Edge
   1     100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes No
   2     100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes No
   3     100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes No
   4     100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes No
   5     100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes No
   6     100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes No
   7     100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes Yes
   8     100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes Yes
   9     100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes Yes
  10    100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes Yes
  11    100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes Yes
  12    100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes Yes
  13    100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes Yes
  14    100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes Yes
  23    100/1000T  | 20000     128  Forwarding   | 941882-a48880 2    Yes Yes
  24    100/1000T  | 20000     128  Forwarding   | 941882-a36540 2    Yes No
