Combine Meridian & ClearPass to improve user experience - 1/3
By Fabien_GIRAUD posted Nov 22, 2016 07:12 PM
I’m pretty sure most of you already know the Aruba Meridian solution. If you don’t, please have a look here to get an idea of its power. In my experience, people that know Meridian tend to think it means “an app for location-aware features and blue dot” but that’s definitively not only that. Based on this page you will learn that one of its many functions is an easy and fast way to build a mobile app for both content delivery and location services.
And what I will show you in this three blogs series (a blog trilogy!) is that you can go even further. You can customise the user experience depending on who is using your Meridian-powered app. This has to deal with Meridan – ClearPass integration (you must know this name “ClearPass”, just in case here is a link).
  • In the first blog you will learn how to configure ClearPass and Meridian to communicate together (main steps) for basic authentication;
  • in the second one, I’ll show how to add some parameters which can be used to customise content delivery;
  • and finally in the last blog, I’ll explain how to deal with this integration to deliver user-specific content.
So now let’s begin our trip. First, you need to know that integration between Meridian and ClearPass uses OAuth2. The process of such authentication is shown (in a really simple way) on the picture below:
As you can imagine (after having seen this picture), the configuration steps will be as follows:
  • ClearPass configuration
  • Meridian configuration
Let’s describe more in detail each of these two steps.
  • Add a new API profile in ClearPass Guest (see below picture for the parameter values):
  • Create a new API client which will be sent by Meridian App (Warning: the name must be “meridian” in lower case)
  • Optional: if you plan to use the ClearPass guest database to authenticate the Meridian App users, you have to define a guest service in ClearPass and also to add a guest login / registration page.
    The advantage of doing this is that the users can use the same credentials to connect to guest wifi AND Meridian App.
    In this case, we can have the following process:
  • Create a service to allow Meridian to authenticate in ClearPass (using Oauth2)
    Enforcement Profile (We’ll customise this in a second blog with additional parameters). You can use the name you want (here I use Meridian Login2)
And the policy: if the user who connects through Meridian App is from the guest db à he’ll have the Meridian Login2 profile we just defined:
And finally the service rule the Meridian authentication will use.
We can also fine tune the service rule. Here (since I only plan to use one Meridian App) all the OAuth2 request will go to this service. But we can also restrict to some client ID or type …
Meridian-CPPM-part1-7.pngIn the Authentication source, we add the Guest User Repository (to be able to use guest account in the App). You can also add other sources (such as the corporate AD so that corporate users can authenticate without having to create guest accounts)
Meridian-CPPM-part1-8.pngAnd we specify the enforcement policy defined before:
Meridian Configuration
To configure your Meridian App, first connect to your favorite website: https://edit.meridianapps.com/
For OAuth2 integration, the only configuration to make on the Meridian side is “Organization à User Login” page. Here we need to specify:
  • “User Login URL” = where to try to authenticate (e.: https://<ClearPass public DNS>/api/oauth),
  • “User Info URL” = where to get info (token + parameters) on the user (e.: https://<ClearPass public DNS>/api/oauth/me)
  • (Optionally) “Create Account URL” = where a user can create a new account, using ClearPass Guest self-registration for example (e.: https://<ClearPass public DNS>/guest/<self_reg_page.php).
WARNING
In order to make the Oauth2 integration between Meridian and ClearPass work, the ClearPass server must:
  • Have a public IP (accessible through HTTPS)
  • Have a public DNS (in a domain you can manage, this is important to be able to generate public certificate for this entry)
  • Have a public certificate (to get one, I used https://startssl.com)
Test it!
Let’s check the basic authentication is working …
We created a test@test.com user in the guest management. And we simulate the Meridian Oauth2 process using HTTPIE command line tool (or CURL, or the fantastic Chrome App: Postman).
Syntax of the httpie cli I used is (in that case we can use local IP since I specified not to verify the certificate in the CLI):
http –verify=no POST https://meridian@<ClearPassIP or hostname>/api/oauth grant_type=password username=<guest username> password=<guest password>
As you can see, the first step is to get an “access-token” …
And we can see the authentication in the ClearPass logs:
Since we didn’t yet add some parameters to the Oauth2 authentication, there’s not much more information to get with this token. So “what else?” … add custom parameters! J
If you arrive at the same result as above, this means that you have the foundation for Meridian authentication via ClearPass and I encourage you to read the second blog of this series around “adding custom parameters”.
I hope you enjoy this first part of the trip. Stay tuned for the next 2 blogs of this Meridian- ClearPass trilogy.
#ALE
#Meridian
#LocationServices
1 comment
Comments
Jan 03, 2018 02:47 PM
 Hi Fabien_GIRAUD,
We have few VLANs that we have deployed in the network across the HPE platform. When a user connects to switch, and clearpass gets it's MAC address. For verification, it should send to an API call to the external asset manager(Bluecat) and asks via an API call what is the VLAN number or name of that VLAN (string value). External asset manager(bluecat) returns a JSON object with the VLAN information against that MAC. Clearpass based on that information (i.e. the VLAN) should assign a particular VLAN to the end user.
Is this doable from the Clearpass perspective? My project looks like the above app integration project so point me in the right direction so that I can build upon it.
Sachin
