Q:
How do you configure SNMPv3 (and credentials) for ArubaOS-Switches?
ASE Link: Go to the solution
A:
This solution will configure SNMPv3 credentials on a switch running ArubaOS-Switch (or the legacy ProVision OS).
Minimum version varies by switch model; should work on any ProCurve/ArubaOS-Switch device running 15.13 or newer.
This solution will configure SNMPv3 credentials, including user accounts, groups, and SNMP options.
Aruba 2530 running YA.16.01.0004
[1] HPE ArubaOS-Switch Software Management and Configuration Guide K/KA/KB.16.01
Our requirement is all snmpv3 access requires SHA Auth and AES PRIV. We also only allow readonly access via SNMP, which it appears the Aruba switches don't support.
While I can create a user with aoth AUTH and PRIV, when I assign the user to a group, the security requirements of the group are what is enforced for the user connection...
It appears the Aruba switches, support the following:
managerauth Require authentication, can access all objects.managerpriv Require privacy and authentication, can access all objects.operatorauth Requires authentication, limited access to objects.operatornoauth No authentication required, limited access to objects.
How do I have a readonly user, that only has read access to the objects on the switch, but is required to use both AUTH and PRIV to connect?
© Copyright 2021 Hewlett Packard Enterprise Development LPAll Rights Reserved.
