Environment : All Aruba OS after 6.3
HOW TO DO DATAPATH PACKET CAPTURE FOR WIRELESS CLIENT FROM CONTROLLER.
Use the following command to enable the Packet capture
(Aruba) #packet-capture datapath wifi-client <mac-address> ?
all Capture both decrypted and encrypted packets
decrypted Capture decrypted packets only
encrypted Capture encrypted packets only
We Need to set a Destination for this capture(You can use either of these options)
(Aruba) #packet-capture destination ?
interface Send captured packets to an interface
ip-address Send captured packets to a remote destination
local-filesystem Store captured packets on the controller in pcap files
(Aruba) #packet-capture destination interface ?
<slot/port> Interface in <slot>/<port> format
(Aruba) #packet-capture destination ip-address ?
<ipaddr> A.B.C.D IP address
(Aruba) #packet-capture destination local-filesystem ?
<cr>
Note:If we use Local file system Capture will be saved in the logs.tar of the controller .
You can also use the following command to Copy the packet capture to the flash
#packet-capture copy-to-flash datapath-pcap
Note: You can tftp/ftp the file out from the flash
