OP: @mrtwentytwo
Aruba has two types of stacking on the switches above the 2530/2540:
VSF is simular to IRF on the Comware switches.
Below is a short instruction to setup VSF. The speed needed as a VSF link is different per switch, lookup the minimal speed needed in the switch manual.
Switch1
Switch2:
You are done!
Attached more information.
Partly based on http://community.arubanetworks.com/t5/Campus-Switching-and-Routing/Configure-Virtual-Switching-Framework-VSF-in-2-steps/td-p/266765
© Copyright 2021 Hewlett Packard Enterprise Development LPAll Rights Reserved.
