Problem:PDB generation failed with code:1 in ALE running in estimation mode.
ALE version: 2.0.0.13
Controller AOS version: 6.4.3.2
Diagnostics:All deployed APs been provisioned in Airwave VisualRF
Airwave/controller details provided in ALE are correct
Checked ale-jwebapp.log and noticed generation is failing with below error
018-01-02 14:19:18.606 BRST [http-nio-8080-exec-1] DEBUG com.aruba.ale.util.PDBScanner - NoScan PDB dir /opt/ale/ale-jwebapp/webapp/download/noscan doesn't exist
2018-01-02 14:19:20.777 BRST [http-nio-8080-exec-5] ERROR com.aruba.ale.common.WrapperProc - Process timeout after 600000 msecs
2018-01-02 14:19:20.912 BRST [StreamDump-ERRSTRM] WARN com.aruba.ale.common.RTStrmDump - Exception message:Stream closed
2018-01-02 14:19:20.950 BRST [StreamDump-OUTSTRM] WARN com.aruba.ale.common.RTStrmDump - Exception message:Stream closed
2018-01-02 14:19:20.951 BRST [http-nio-8080-exec-5] ERROR c.a.ale.noscan.NoScanPDBGenerator - PDB generation failed with code: 1
SolutionPDB generation is failing due to RTLS exception messages
Noticed RTLS is enabled in ALE server. Disabled RTLS option and regenerated the PDB file.
Note: ALE RTLS is currently not supported in AOS 6.5.4.2 and below code. Support is been added from 6.5.4.3 code.
#ALE
