How to disable whitelist DB sync in the Master - Local controller setup?
By esupport posted Nov 06, 2018 04:22 AM
In deployments, where there are many controllers and AP with CPSEC involved, having whitelist DB synced across controllers may cause unwanted DB utilization. For eg, if we have 10000 APs across 10 controllers, with whitelist DB sync enabled, all 10000 AP entries would be synced across all 10 controllers. If any controllers in the cluster is not used for terminating APs, then having its DB utilized may be unneccessary.
In cases, where we do not want whitelist DB to be synced between Master and Local controller, we can disable it.
Note: This command is applicable on Master only.
To Disable whitelist DB sync:
(Aruba7240-164.10) (config) #disable-whitelist-sync
Whitelist sync has been disabled
(Aruba7240-164.10) (config) #end
(Aruba7240-164.10) #show whitelist-db cpsec-status
Wed Oct 31 03:40:22.188 2018
My Mac-Address                00:1a:1e:03:d1:c8
My IP-Address                 10.29.164.10
Master IP-Address             10.29.164.10
Switch-Role                   Master
Whitelist-sync is disabled                                 <<<<<<<<<<<< DB sync disabled
Entries in Whitelist database
Total entries:                3
Approved entries:             2
Unapproved entries:           0
Certified entries:            1
Certified hold entries:       0
Revoked entries:              0
Marked for deletion entries:  0
Current Sequence Number:    4
To enable whitelist DB sync:
(Aruba7240-164.10) (config) #no disable-whitelist-sync
Whitelist sync has been enabled
(Aruba7240-164.10) (config) #show whitelist-db cpsec-status
Switch-Role                   Master
Whitelist-sync is enabled
Total entries:                1
Approved entries:             0
Revoked entries:              0
Current Sequence Number:    2
Before whitelist DB sync disabled
On Master:
Wed Oct 31 03:39:14.068 2018
Control-Plane Security Whitelist-entry Details
MAC-Address        AP-Group  AP-Name  Enable   State                   Cert-Type     Description  Revoke Text  Last Updated
44:48:c1:ca:66:ec                     Enabled  certified-factory-cert  factory-cert                            Thu Sep  6 15:05:35 2018
Total Entries: 1
(Aruba7240-164.10) #whitelist-db cpsec add mac-address 44:48:c1:ca:66:bb ap-name APw
Wed Oct 31 03:39:38.669 2018
44:48:c1:ca:66:aa            APx      Enabled  approved-ready-for-cert  switch-cert                             Wed Oct 31 03:39:14 2018 <<<<< Entry added on Local
44:48:c1:ca:66:bb            APw      Enabled  approved-ready-for-cert  switch-cert                             Wed Oct 31 03:39:34 2018 <<<<< Entry added on Master
Total Entries: 3
Wed Oct 31 03:39:48.658 2018
Switch-Role                   Master
Total entries:                3
Approved entries:             2
Revoked entries:              0
On Local:
(Aruba7240-164.30) #whitelist-db  cpsec add mac-address 44:48:c1:ca:66:aa ap-name APx
(Aruba7240-164.30) #show whitelist-db cpsec
Wed Oct 31 03:44:16.627 2018
44:48:c1:ca:66:ec                     Enabled  certified-factory-cert   factory-cert                            Wed Oct 31 03:43:03 2018
44:48:c1:ca:66:aa            APx      Enabled  approved-ready-for-cert  switch-cert                             Wed Oct 31 03:44:12 2018 <<<<< Entry added on Local
Total Entries: 2
(Aruba7240-164.30) #show whitelist-db cpsec-status
Wed Oct 31 03:44:23.969 2018
My Mac-Address                00:1a:1e:03:87:c8
My IP-Address                 10.29.164.30
Switch-Role                   Local
Total entries:                2
Approved entries:             1
Revoked entries:              0
Current Sequence Number:    6
Wed Oct 31 03:45:20.812 2018
Switch-Role                   Local
Total entries:                3                       <<<<< Value moved to 3 post a new entry added on Master
Approved entries:             2
Revoked entries:              0
Current Sequence Number:    7
Wed Oct 31 03:45:23.503 2018
44:48:c1:ca:66:bb            APw      Enabled  approved-ready-for-cert  switch-cert                             Wed Oct 31 03:45:04 2018 <<<<< Entry added on Master
Total Entries: 3
Post disabling whitelist DB sync on Master:
On Master
Switch-Role                   Master
Whitelist-sync is disabled                                 <<<<<< Sync disabled
Total entries:                3
Approved entries:             2
Revoked entries:              0
(Aruba7240-164.10) #whitelist-db  cpsec add mac-address 44:48:c1:ca:66:cc ap-name APe       <<<<<<< added a new entry on master
Wed Oct 31 03:40:59.095 2018
44:48:c1:ca:66:cc            APe      Enabled  approved-ready-for-cert  switch-cert                             Wed Oct 31 03:40:56 2018
Total Entries: 4
Wed Oct 31 03:51:16.736 2018
Switch-Role                   Master
Total entries:                4
Approved entries:             3
Revoked entries:              0
Current Sequence Number:    5
On Local
Wed Oct 31 03:46:32.733 2018
Switch-Role                   Local
Total entries:                3                       <<<<<< On master, total entry is 4 whereas on Local its 3 post db sync disable
Approved entries:             2
Revoked entries:              0
Wed Oct 31 03:46:37.209 2018
Total Entries: 3
1 view
