AOS and CPPM – Dot1x Authentication and integration
By JuliaOstrowski posted Sep 24, 2014 04:26 PM
EAP-TLS and EAP-PEAP are two of the most highly used authentication mechanisms on enterprise WLAN.
This presentation gives a detailed step by step procedure for setting up a Controller and CPPM for EAP-TLS & EAP-PEAP – with and without EAP termination on controller.
Importantly, it covers setting up the PKI infrastructure required for these authentication mechanisms. It also looks in to detail troubleshooting tools and commands available in both AOS & CPPM.
AOS CPPM Integration - Configuration Testing document for EAP TLS EAP PEAP v2.pptx
2 comments
Comments
Jul 15, 2015 08:52 AM
The doc is already attached
Jul 15, 2015 04:12 AM
Update: Found the attachment, thanks! :)
