How to monitor a CPPM cluster via Airwave
By esupport posted Mar 26, 2017 03:25 PM
Q:
I have a cluster of 16 CPPM nodes. What is the best way to monitor all the nodes via Airwave
A:
SNMP configuration is a server specific configuration, so it must be updated on all the nodes.
Steps - From CPPM webUI :
Under - Administration » Server Manager » Server Configuration - Select the server and update the SNMP config under System Monitoring tab.
Once we have the snmp configuration in place, we will have to manually add each node manually as a new CPPM device to Airwave.
Alternatively network scan  option can be used to discover all active devices in that subnet.
1 view
