When does a Master Instant AP transition to a Local? Will an IAP reboot, if it transitions from Master to Local?
By Arunkumar posted Jun 27, 2014 07:59 PM
Environment : Mutiple IAPs in a subnet in the same code version.
Master transitions to local, when it hears another master in the same subnet and if it loses the master election with that other Master IAP.
Following is the criteria used to elect a master when there are more than one master in a subnet.
  1. IAP with Non-default IP addr(Non-169.x.x.x) takes priority
  2. IAP with 3G dongle gets higher priority
  3. IAP platform checked, AP135 gets priority
  4. IAP with higher uptime
  5. IAP with a bigger MAC address
The IAP that loses the election transitions to slave and reboots to come back and join the swarm as slave.
6c:f3:7f:cc:3d:2a# show version
ArubaOS (MODEL: 105), Version 6.2.0.0-3.2.0.3
Website: http://www.arubanetworks.com
Copyright (c) 2002-2013, Aruba Networks, Inc.
Compiled on 2013-04-01 at 10:04:08 PDT (build 37855) by p4build
AP uptime is 1 hour 22 minutes 2 seconds
Reboot Time and Cause: AP rebooted Mon Apr 8 13:59:09 UTC 2013; master transitioned to local <<<<<<<
