Hello Mohammad,
If you want you can check the scrits for config backup , there are some for PaloAlto
C:\Program Files\iMC\server\conf\adapters\ICC\PaloAlto\PaloAltoCommon
All adapters are in the C:\Program Files\iMC\server\conf\adapters\ICC folder .
You also need to add the sysoid of your device in the adapter-index.xml to force the system to use the adapter.
Hope this helps you further .
Marina
HPE
Sofia
Original Message:
Sent: Apr 21, 2022 06:11 AM
Subject: help with IMC backup third party....
Hello everyone,
I'm trying to backup FortiGate and FortiAnalyzer and Palo Alto from HPE IMC but can't same to understand how to work, I read the post here and the administrator guide to how to create an adapter and sysOID file in IMC but can't understand what should be inside adapter file?
can anyone help ?
Best Regard
Mohammad AlHaddad
