Wired Intelligent Edge
  • 1.  16.02 Tunneled-Node per-port presentation
    Posted Jul 26, 2016 09:07 PM
    Hi All,
    Recently in the new ArubaOS-Switch 16.02 firmware, the Tunneled-Node Per port feature was introduced.  Attached is a presentation by the HPE Aruba Campus Switching TME Team that provides further investigation into Tunneled-Node per-port, best practices, how to configure it, and how it can unify policy enforcement within the network.
    Justin
  • 2.  RE: 16.02 Tunneled-Node per-port presentation
    Posted Jul 28, 2016 04:49 AM
    Hi!
    Is there a requirement on firmware version on the controller? I´m running into issues, we´re running ArubaOS 6.4.4.6 on the controller.
    I see the tunnel forming from the switchport to the controller but when checking the datapath tunnel I can´t see any decaps on the tunnel coming from the 2930F port.
    We have a working MAS S1500 installed which I believe confirms the configuration of the controller is correct.
    Any ideas?
    Cheers,
  • 3.  RE: 16.02 Tunneled-Node per-port presentation
    Posted Jul 28, 2016 09:23 AM
    6.5+ on the controller side .
  • 4.  RE: 16.02 Tunneled-Node per-port presentation
    Posted Jul 28, 2016 09:56 AM
    Hi!
    Thanks for the answer, do you know if there´s any plan for implementing support for this in the 6.4.4 train of code? This customer can´t run 6.5 as of now.
    Cheers,
