367 AP reload continuous reboot
  • 1.  367 AP reload continuous reboot
    Posted Nov 11, 2019 07:51 AM
    Hello all,
    kindly i need your support in the below issue
    Date received from You
    14-06-2018
    PN
    JX970A
    SN
    CNDCJSX0RM
    Report from our technical team,
    Issue description :
    Troubleshooting Steps Taken :
    • connect to AP with console cable found the error attached
    • try to reset it factory default and rest flash nothing changed
    • try to boot via tftp , AP get OS from controller and reboot but can't open also finally rebooted with same error
  • 2.  RE: 367 AP reload continuous reboot
    Posted Nov 12, 2019 04:57 AM
    the AP appears to have a flash memory fault, please raise it with TAC to organise a RMA etc.
  • 3.  RE: 367 AP reload continuous reboot
    Posted Nov 19, 2019 06:51 AM
    Thank you dear
