Comware
  • 1.  5300 mesh
    Posted Jun 25, 2003 10:44 PM
    if i use mesh domain on 4 5308, can i use L3 funtion on other ports?
  • 2.  RE: 5300 mesh
    Posted Jun 26, 2003 12:42 AM
    Are you sure you can do meshing with 5300XLs? I know this is not possible with 4108GLs - the only option I have on 4108GLs for redundancy is RSTP. But meshing was possible with the 4000Ms.
    Cheers,
    Dan
  • 3.  RE: 5300 mesh
    Cheers,
    Dan
  • 4.  RE: 5300 mesh
    Posted Jul 02, 2003 10:45 AM
    Sorry Rai !
    But the HP Procurve 5300xl Series product does not support enabling routing and meshing concurrently. If you have meshing enabled (no matter on how many ports) the system will not allow you to enable routing until you disable meshing and vice versa.
    I assume you mean routing when you mention L3 function ?
    BR,
    Dmitry
  • 5.  RE: 5300 mesh
    Posted Jul 07, 2003 12:42 AM
    Thanks Dmity
